SignalExpress
TDMS to Analog Output
I have a big TDMS file  (>10 seconds of two channles at 500ksps). I'd like to output it from an analog output. I looked into the Load Signalsand it seems like TDMS isn't in there.
(4,836 Views)
There are some great resources tha you can use with LabVIEW for importing TDMS files and then converting that into a numeric to be written using analog. There are some shipping examples that come with LabVIEW that can be found at Help>>Find Examples.... TheTDMS read and write can be found under Fundamentals, then the File Input and Output. In this folder there are several other options for you to explore. There is a folder called TDMS and an Advanced. I suggest looking through some of those VI's, which will lead you in the right direction.
(4,815 Views)
So you're saying  "No, you can't do that in signal express"?
(4,808 Views)
(4,801 Views)
Yes, I can import the TDMS and see it in the logs section but I cant figure out how to get it from there to the "steps" section so I can send the signal to an AO
(4,759 Views)
