SignalExpress
Tektronix edition - Log import
Hi all,
I've got a problem, which I can't solve on my own, so I'm asking your help.
I've got the softwareprogram: SignalExpress Tektronix edition v2.5.1
Now in this program you got the option to record your measurements, wonderful!
But I accidentely deleted one of my files and I can't remeasure it anymore.
What happend: I pressed on the delete button for a couple of file (one to much..) and removed them from the project (left on the disk).
Now I wan't to get back one of those files, but it just won't work...
When I try to import the file like: "Logged Signals From Another Project" then it just won't see any file so I tried the other option:
"Logged Signals from SignalExpress TDMS Files…" (see: http://digital.ni.com/public.nsf/allkb/40499FC78C039BC386257944004D4450).
I can see the files now, but still can't load them into my project.
I'm getting an error: "You cannot choose this folder name; a file of that name already exists" then (see figure)
But there aren't any log files named like that. even tried with a blank project, still same result.
How to fix this? because I really need that data.
Kind regards,
Dennis1001.
(6,321 Views)
Accepted by topic author Dennis1001
Hello Dennis,
It seems like you selected a specific file instead of a folder.
In the pop-up message they mention:
"Choose a folder that contains tdms file"
So when you're in the right folder, you should choose/click "Current Folder" instead of selecting a specific tdms-file.
Can you try this?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(6,298 Views)
Wow I missed that completely!
Thanks a lot, thats the solution!
(6,285 Views)
Thanks for letting us know!
Can you mark this post as resolved?
This way other forum visitors can also easily find posts that contain solutions.
Kind Regards,
(6,283 Views)
