SignalExpress
Temperature to Voltage in Signalexpress
Hello.
I have taken thermocouple (type B) readings from two thermocouples with SignalExpress. The problem is that one of the thermocouples was switched (+ to - instead of - to +). This wasnt seen before the measurement started because they start to give a reading at approximately 70 degree C. Now i need to get the raw data for this reading so i can see if its possible to just multiply the raw EMF data with -1 and apply the temperature polynom again. I guess one way would be to calculate it backwards with the polynom assuming its the same as ITS-90 for type B. So is there any easy way to acess the raw EMF values for a choosen channel after the reading has been done?
Sincerely
Ola
Message 1 of 1
(6,242 Views)
