SignalExpress
Time stamp of peaks
I have a Signal from SignalExpress 2010 that has peaks within otherwise noisy data. I would like to get time stamps recorded to an ASCII file on where those peaks are in each sample of my Signal. I have tried doing a Limit Test that would trigger a Conditional Repeat that houses an ASCII writer, but it only tells me whether that sample had peaks.
Any tips on this?
(5,712 Views)
Those type of calculations are more suited for LabVIEW.  Signal Express is limited in what computations it can do with data after it is recorded.  A tutorial on peak detection in LabVIEW is located here: http://zone.ni.com/devzone/cda/tut/p/id/5432
Aaron
(5,704 Views)
