SignalExpress
Toggle trigger after file close
I'm new to Labview. I have a application needs to toggle Trigger and Ready signal, if a trigger input channel reach a set level, Trigger will be set to True and Ready will be set to False; then the system will record data to disk (in RT local), while Ready is False, the system will not check trigger channel level; after recorded set number of samples, close the file and set Ready to True, clear Trigger to False. I use Write to Measurement File express VI to record data, but I could find the way to toggle Ready and Trigger.
Please help me out here. Thanks!
(7,431 Views)
Accepted by topic author wusup
My system is cRIO9073, code attached
(7,425 Views)
So, are you already doing what you would like? I just wanted to confirm as you had set your second post as the solution.
Vivek Nath
Machine Vision
(7,405 Views)
I added a counter to do it, but looks like the scan engine only sample one channel each scan, still need to work on it, thanks!
(7,399 Views)
