SignalExpress
Track Entire Log By Default?
In SignalExpress is there any way to track the entire log by default?  I have set the logging options to inherit playback configuration but that doesn't do it.
Thanks.
(6,364 Views)
I was able to find the following KnowledgeBase article, does this address your issue?
Signal Express: Display All Data History in Data View While Acquiring Continuously.
Glenn
(6,340 Views)
Thanks for the reply.
The method you linked to is how we are doing it now.  I was just hoping that the "Entire log" option could be set as default rather than having it reset to "Current data\buffer" each time a new log is created.
Seems like something like that should be doable by changing a registry key but I guess not.
(6,328 Views)
Due to the sensitivity of registry keys we typically recommend against any modifications to the registry.
Glenn
Glenn
(6,312 Views)
