SignalExpress
Trigger options using Signal Express with 9233
I want to capture a transient signal from an accelerometer using a trigger. The only option that appears to be available is a software trigger. Is that correct? In other words, I have to manually trigger the software to start capturing data. Is this right?
(6,177 Views)
I think this KB on 9233 triggering will explain why you're seeing what you're seeing.  Take care!
(6,165 Views)
