SignalExpress
Trying to log data - some seems to be missing
I have a Tektronix TDS1012B with a memory of 2500 samples.
I am trying to log continuously using Labview signal express 2.5.1 tektronix edition.
I set up an aquire step then a save to ASCII step. Then I click run (not the run once button). Then I click stop.
I run for about 4 seconds and get 10ms worth of data.
I can see it saying idle -> running -> waiting for trigger four times while I run for approx 4 seconds.
The signal is a 50hz square wave with a positive pulse width of 1 to 2 ms.
I have set the oscilloscope to  a timebase of 250us, which gives 1 microseconds for each sample.
I have attached my project file and the ascii file that results.
Please help.
Message 1 of 1
(5,542 Views)
