SignalExpress
USB-6009 generate sine wave using Signal Express
Can I use USB 6009 to generate sine wave by using only Signal Express ?
(4,337 Views)
Hi Kunso,
Yes you can, you can find a quick example of how to do that here.  It also includes an example project for you to download if you need.
(4,299 Views)
Thanks Euge Or Pat
The amplitue of signal quite very small. So, how I can increase amplitude to 2 volt because I found some error when I tried it.
(4,276 Views)
What do you mean when you say you're getting some error? If the error is at a very small voltage range then it might be a resolution issue of your device.
(4,269 Views)
