SignalExpress
VI to tare Waveform Data
I am trying to develop a VI that will allow me to take in a voltage signal from signal express and tare the signal then output the waveform signal.
I have created a VI that I thought should work.
Any help would be appriciated.
I am using SE 2011.
Tim
(7,442 Views)
Hello Tim,
I would suggest using shift registers instead. Here is a link that describes how to use them:
http://www.ni.com/gettingstarted/labviewbasics/shiftregisters.htm#Initializing Shift Registers
-Erik S
(7,416 Views)
I have tried that and I do not get any waveform output.
Has anyone else got a VI to work where they take waveform as input, perform some operation and display the waveform output?
Tim
(7,403 Views)
You can also try using the Waveform Scale and Offset function. If you take the Y component of the waveform and use it as an offset, you should be able to output a new "tared" waveform. The Y component would need to be negated, though, because the offset function adds the offset instead of subtracting. The unbundle function can be used to get the Y component of the waveform. The following links demonstrate the offset and component manipulation of the waveform bundle.
http://zone.ni.com/reference/en-XX/help/371361J-01/lvwave/waveform_scale_and_offset/
https://decibel.ni.com/content/docs/DOC-8481
https://decibel.ni.com/content/docs/DOC-26873
-Erik S
(7,385 Views)
I have no doubt these solutions work when runing the VI in labview but I am try to get this to work in Signal Express.
I have followed the steps illustrated here http://digital.ni.com/public.nsf/allkb/359D14941D6936E98625729D008387D5
but for what ever reason I cannot seem to get any out put from the attached project.
Tim
(7,167 Views)
You've been using LabVIEW for a couple of years and should know that a lvproj does not contain any code. You need to attach actual VIs.
(7,163 Views)
My mistake I though I attached the correct file.
Tim
(7,160 Views)
