SignalExpress
Viewing entire data set
How can I view the enire data set in the data view? Currently, I can only view 0.4 s of data at a time. I am recording about 2 s of data using continuous sampling at 250 kHz with a buffer of 100k.
Thanks.
(6,812 Views)
Dragging the output of your acquisition step into the Data View will only show you the data for that last acquisition. But if you are recording, then a new log will appear in log folder located in the bottom left side of your application in the project view. Dragging that log into the Data View will display the entire log.
Phil
(6,805 Views)
Phil,
Thanks. This was very straightforward. Much appreciated.
(6,796 Views)
