SignalExpress
Why can't I display more than 1 second worth of data on live graph
When I re-scale the timebase on the data view (like 0 to 5 seconds) I still only see 1 sec worth of data on the screen.
(6,223 Views)
Unless you are logging/recording data, SignalExpress simply shows you the latest values for your data. Since the results produced by your steps are most likely returning only 1 second chunks of data, that's all the data the live graph can show you.
Can you provide more information on what you are trying to do?
Phil
(6,221 Views)
Thanks Phil, I think I figured it out.  I was only capturing 1000 samples @ 1kHz so the graph was just displaying this information.
(6,207 Views)
