SignalExpress
XY Graph of pressure vs strain
I am using cDIQ-9174, NI 9236 & NI 9237 to measure the strain and pressure along the pipe. I can see the independent waveforms however I want to plot and a snapshot of the XY graph of pressure vs strain which will start from (0,0) and give me whatever succesive datapoints. All I could plot is XY graph which does not start from (0,0). How do I do that?
(5,980 Views)
Can you post your .seproj file or a screenshot of your project window.
Your signals will start at whatever reading they're at at the time of acquisition. In other words, if you're showing 5,000uE and 50psi at rest (or at the time you hit record) that's where your graph will start. Are you removing any offsets before logging data?
SCXI- 1000 Chassis w/ 1346 adapter
PCI 6281 DAQ card
SCXI- 1520 Bridge Board w/ 1314 Terminal Block (x2)
SCXI- 1180 Feedthrough Panel w/ 1302 Block
Signal Express 2014.
Win7 Enterprise
(5,970 Views)
