SignalExpress
activate IEPE
Hi at all,
I'm from Germany so I hope my English is good enough to describe my Problem:
I want to measure and record an acceleration using a Brüel & Kjaer accelerometer (Type 4613B). I'm using a NI 9234 USB device and SignalExpress 2011.
For using the sensor I have to activate IEPE, but I dont know where I want the settings for that. I've testet the sensor with NI MAX, where it was easy to find the setting for IEPE: With activated IEPE the sensor works well.
Harry
(8,910 Views)
Hi Harry,
i used SignalExpress 2012 with a simulated NI cDAQ-9171 single carrier chassis and a NI 9234.
I found the following option to activate/deactivate IEPE exitation
Regards, Stephan
(8,902 Views)
The png does not show up for me. Is there another way you can display the solution?
(5,106 Views)
