SignalExpress
cFP-1804 Supported by Signal Express?
Does Signal Express (Version 2.0.0) work with a cFP-1804?
What about other cFP controllers (ie cFP-2120)?
(6,935 Views)
Hello Barty,
Our Field Point products are not supported with Signal Express. I reviewed the ReadMe for Signal Express. Here is a list of the drivers that are supported:
LabVIEW SignalExpress is compatible with the following products:
  • NI-DAQmx 7.3 or later
  • NI-SCOPE 2.7 or later
  • NI-FGEN 2.2 or later
  • NI-HSDIO 1.3.1 or later
  • NI-HWS 1.3.1 or later
  • NI-DMM 2.4.1 or later
  • IVI Driver Toolset 2.0 or later
LabVIEW SignalExpress will install or update the following applications:
  • MAX 4.2.1
  • LabVIEW Run-Time Engine 7.1
  • LabVIEW Run-Time Engine 8.0
  • LabVIEW Run-Time Engine 8.2
  • IVI Compliance Package 2.0 or later
  • NI-VISA 4.1.0
  • Microsoft .NET Framework 2.0
I hope this answers your question.
Cheers,
Emilie Kopp | Applications Engineer | National Instruments
(6,917 Views)
While SignalExpress does not natively support Fieldpoint, it should be relatively simple to write data acquired by an FP device to a shared variable (if you are not sure how to do this, consult the help/devzone documents), and then use the Shared Variable step in SignalExpress to acquire the data.
Patrick
(6,904 Views)
