SignalExpress
calibration file
My "custom calibration" drop down in Step Setup in the Acquire data step is grayed out although the name of each instrument is there.  Apparently SE can't find the calibration file?  Where would the file be stored?
(5,634 Views)
Hi mrelet,
What hardware are you trying to calibrate?  By custom calibration drop down, are you talking about the Calibration tab in the Configuration Tab setup?  Some hardware is not calibratable, so that could be a possible reason it is grayed out.
Kyle A.
Senior Applications Engineer
(5,620 Views)
