SignalExpress
conflict of two inputs
Help to realize this simple program (for example) in Signal Express.
I have 15 waveforms (15 channels), they were read from one uff file (use step "Load from uff file").
For my task I need in first input select one channel (BASE CHANNEL).
In second input select all channels (CHANNELS).
When I take BASE CHANNEL and CHANNELS from different files it works correctIy.
I need take them from ONE file.
When I run ""program pending".
(6,447 Views)
Hello Irafka
You can always call a VI from SignalExpress, if you are more proficient with LabVIEW. Here is a little knowledge base on how to do it.
Using a LabVIEW VI with LabVIEW SignalExpress
http://digital.ni.com/public.nsf/allkb/359D14941D6936E98625729D008387D5?OpenDocument
Fabián M.
Internal Sales Engineer
(6,423 Views)
You don't understand me.
I needn't read this documentation. I knew it very well.
I learned it about one year ago.
I'm not a beginner in SE and in LabView.
My question is not how to open this diagram in SE.
I did it, but didn't work.
Let me to describe my problem once again.
Please, read all that I write below and please try to help me.
I work in SE:
1. First step - standart step "Load from uff file".
In the output I get 15 waveforms (15 channels - array of the waveforms) from this file.
2 Second step - load my VI (this VI in diagram).
In first input select one channel from array (BASE CHANNEL).
When I run occure "program pending".
Why? It's very simple task.
(6,406 Views)
Ok Irafka, I understand your issue now. If you upload your uff file, I can try to reproduce your problem on my computer in order to try to find an answer.
Fabián M.
(6,385 Views)
Hello, I sent you my file.
(6,352 Views)
