SignalExpress
controlling direction of DIO ports of USB-6008
How does a person control the direction of the DIO ports in the USB-6008?  And how does one then receive a signal (if dir = in) and send a signal (if dir = out)?  Sorry, I'm new to Signal Express.
(5,525 Views)
Hi Tim,
In general, the direction (input or output) depends on the type of step you define in Signal Express. As you can see, when you see the Add Step options, you have the option to both Acquire Signals (dir = in) and Generate Signals (dir = out).
Hope this helps!
~kgarrett
District Sales Engineer
(5,519 Views)
