SignalExpress
cross power spectral density
Hello
I can not figure out how to use "Cross Power Spectral Density" (CPSD)
in Labview. I know that Labview has something about
"Cross Power Spectrum" but I need Cross Power Spectral
Density, because I am going to measure the coherence which
needs CPSD as far as I know.
Thaks for your help
(6,517 Views)
Hi kiarash,
I am not familiar with cross power spectral density or calculating coherence.  However, there are some other forum topics that might be useful for your application:
Topic: Problem to calculate the coherence (using NetworkFunction-VI) with only 1 row of data for eac...
Topic: power spectral density.vi
You might also want to look at the following document for further information:
The Fundamentals of FFT-Based Signal Analysis and Measurement in LabVIEW and LabWindows/CVI
(6,502 Views)
