SignalExpress
display temperature in table view
Hello!
I'm recording some temperatures via Pt1000 probes and WAS ProRTD isolation amplifier which gives for example 10V on 120 °C.  But in signal express I can only get waveforms, and I need digital temperature data, such as on display. Sample rate is 1 Hz. How to do it?
(6,319 Views)
Try this:
  • Add an Amplitude and Levels Step after your DAQmx Acquire step
  • Select the channel you want to monitor and keep DC Values checked (uncheck RMS)
  • Create a new display (or new Data View) and drag the DC Values into this display.
  • Now right click on the new DC Values display and select View As...  Large Display.
  • From there you can edit the properties of the display to your liking. Such as padding, significant digits, etc.
Is that what you're looking for?
SCXI- 1000 Chassis w/ 1346 adapter
PCI 6281 DAQ card
SCXI- 1520 Bridge Board w/ 1314 Terminal Block (x2)
SCXI- 1180 Feedthrough Panel w/ 1302 Block
Signal Express 2014.
Win7 Enterprise
(6,318 Views)
