SignalExpress
gain
I'm conducting pressure measurements with SCXI 1520 and 1314. Data aquisition etc with signal express works well, but since the output voltage is quite small I want to amplify the signal. The SCXI 1520 has a built in amplifier, but I could not find anything on the activation of the GAIN signal Express.
Any help is appreciated.
Franz
(5,720 Views)
If you are looking for just software gain, you can use 'Scaling and Conversion' step. If you are talking about setting the gain onboard for SCXI 1520, from what manual says, I don't think you can do that using Signal Express, you might just have to use LabVIEW vi.
Kudos are (always) welcome for the good post. 🙂
(5,630 Views)
