SignalExpress
how to log multi channel simultaniously
I am using signal express v.2.5.0  with a Keitley 2701 and a 7700 20ch multiplex card.
I can not figure it out: how to log several channels symultaniously.
For example i like to log 10 temperature's in a device at the same time.
How to configure signal express to do so?
Thanks for the help.
M Donners
Maastricht University
(6,472 Views)
How do the 2701 and 7700 work together? As I can see the 7700 is a plug in module for the 2701. Do you need to control them both manually or does it switch when the 2701 has done a measurement.
What steps are you using in Signal Express to controll the Instuments? IVI DMM?
What you can do is use a sweep step to sweep trough all your channels. you can then configure the sweep output as a  plot/array of measurements against the channel number.
Hope this helps
Regards
Karsten
(6,454 Views)
If you are using the IVI DMM to acquire the data then you are limited to 1 channel.  If you are OK with using beta software you can sign up for the SignalExpress Step SDK at www.ni.com/beta.  Then we can send you an example Keithly 27xx step which supports multiple channels.
(6,450 Views)
