SignalExpress
integer and derivate in the function of time
hi everybody, i am witting this to ask you about if is possible to integer and deribate in the function of time in signal express...
what i want to do is, to catch data from a NI usb and integer this data using formula....
do you understand me??
sorry my english is not very good
(6,376 Views)
SignalExpress does not currently support integrals or derivatives.  You can create the functionality yourself, if you have a copy of LabVIEW, by using the User Step.  See the documentation for details and examples.  You may also want to file a suggestion in this thread.
(6,375 Views)
ok thanks and can you answer a simple quetion??
1- i have done a labview program with some shared variables, that then i read it from signal expres, and the i record them, but signal express create one tdms for each variable and what i want is to create only one tdms file for each vaariable...can you help me?
(6,371 Views)
Currently, SignalExpress logs each output into a separate file.  I feel like a broken record, but could you file that as a suggestion, as well?  You are not the first to ask for it, but the more customer requests we get, the more likely it is to get done.  Thanks!
(6,358 Views)
