SignalExpress
log 8 hours sound pressure data
Hi all,
I want to log an 8 hour signal from a pcb mic. with the sound and vibration assistant(signal express). I want to acquire at 50KHz, but i think there wi'll be too much data. Is there a WAY to reduce that data?
thank you
pollon
(6,858 Views)
HI Pollon,
what about averaging the signal in a certain amount of time, to reduce the number of points you have to save?
If for example you're acquiring at 50 Hz, you can save the mean value for every 50 points, and in that case, you're saving one point each second.
Hope it helps,
have a nice day!
(6,826 Views)
Could you please give me some help how yo do it?
pollon
(6,787 Views)
Accepted by topic author pollon
There's a processing function called time averaging that does the average:
http://screencast.com/t/ybgMtLvTf4
Have a nice day.
(6,785 Views)
