SignalExpress
memory full error in Signal express
Hi All,
I am trying to log the data using Signal express for 14 channels sampling at 50kS/s. I have a test where we need to perform a continous logging for 100 hours at 50kS/s and samples to read as 5000 .I did a test logging for 24 hours, but Signal express stopped running after 15-16 hours. Do you have any suggestions ?  I am attaching the screen shot.
I am writing the .tdms files to an external HDD (3 TB) and using a Windows 7 PC.
Please let me know if you have any suggestions
(7,116 Views)
That is a considerable amount of data to be continuously logging.
How much system memory does your computer have?
Some suggestions you could try would be to (if you have admin rights) disable any unncessary processes that launch at startup. Increase your page file allocation or at least open the task manager and take a look at the PF activity.
What interface type does your external HDD have? If its anything other than SATA I, II, or III that may be contributing to your bottleneck.
My guess is that its a system limitation and not a Signal Express issue. But I may be wrong.
I've logged data for days on end without issue before; although not at the sample rate you are.
SCXI- 1000 Chassis w/ 1346 adapter
PCI 6281 DAQ card
SCXI- 1520 Bridge Board w/ 1314 Terminal Block (x2)
SCXI- 1180 Feedthrough Panel w/ 1302 Block
Signal Express 2014.
Win7 Enterprise
(7,095 Views)
Hi there,
Thanks for your response, My Computer has a 8GB physical memory . I have allocated 40 GB of virtual memory on my PC .
The external HDD i am using is a 3 TB and has a USB 3.0 interface
(7,090 Views)
If time allows I'd reduce your sample rate by 1/2 and see if your errors continue. If no errors my guess is its a hardware limitation (8Gb isnt a TON of memory).
As I'm sure you know, USB3 devices need to be plugged into a USB3 port to get its max throughput. Plugging USB3 into USB2 for instance will yield USB2 speeds.
PCI 6281 DAQ card
Win7 Enterprise
(7,088 Views)
Hi
I use a USB 3.0 device and my PC has a USB 3.0 port . Yesterday I tried sampling at 25 kS/s and I am still facing the memory problems. Does signal express save a copy of log file information in Memory ?
Sakthivel
(7,082 Views)
I never log to .tdms so perhaps it does save it to memory then "flush" it when you stop recording?
I always save to ASCII.
Sorry I cannot be of more help.
Perhaps an AE will chime in and advise on how to optimize your logging function.
PCI 6281 DAQ card
Win7 Enterprise
(7,080 Views)
Hi, it appears that this is a known issue with how SignalExpress calls TDMS write - it builds a cashe in memory and doesn't normally flush it.
https://www.ni.com/en/support/documentation/bugs/13/archived--labview-2013-and-2013-sp1-known-issues...
There are some possible solutions here - https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019MfNSAU&l=en-US
May I suggest building your own labview application to solve this issue.
Joe
(7,059 Views)
