SignalExpress
peak frequency detection in HZ
Dear all ,
I would like to use use peak detection function (if it is present in signal exptess) to detect the peak frequency from my FFT signal. I sometimes have more peaks and it is time consuming to detect all the peaks manually. Can anyone give me any suggestion.
sincerely,
Munir
(6,094 Views)
Hello Munir,
here are some I hope helpful informations for you. The first thing I would do is to check the example finder. There are several examples which implement the peak detection functions, just type peak in your example finder.
Best wishes,
Jan Kniewasser | Applications Engineer | Tel.: +49 89 7413130 | Fax: +49 89 7146035
(6,075 Views)
