07-08-2011 11:33 AM
Labview SignalExpress crashed on me and resulted in the .seproj file being corrupted. The files says there is 0bytes in the file.
Therefore, i tried to make a new project and imported the logged signals from TDMS files.
I can view the data in playback options, but when i drag the data into the data view, nothing shows up
right clicking the data and clicking show value shows nothing either
i tried playing around with the scale and graph settings but nothing works.
Help Please.
07-11-2011 07:30 AM
If you can, zip your TDMS file directory and post it so we can have a look. Also, what version of SignalExpress are you using?
07-11-2011 10:23 AM - edited 07-11-2011 10:25 AM
Alan,
Sometimes your TDMS Index file can become corrupted, causing problems. If you delete the <filename>.tdms_index file, and then try to reopen your data in SignalExpress, it will generate a new index file automatically. Let me know if this works for you, and if it doesn't then if you can shoot us your file as Damien suggested, then we can continue to look into this.
07-11-2011 01:25 PM
Hey I am working with Alan.
I tried deleting the index file but that didnt solve the problem when loading the logs into SignalExpress. The version is 3.0.0 running on Windows XP Profession x64 Edition
Any other suggestions are appreciated
I will try to upload the tdms files later
