SignalExpress
signal express for tektronics trigger function
I link tds2014 to computer using usb port, I use signal express for tektronics. My application is to continuously get the data from 2 channels(channel 1, channel 2) and save the data at the same time. I can link tds 2014 to my signal express. But I do not understand the content in trigger tab, the content in trigger tab is default trigger by channel 1, I try to change that, but after that, I can not acquire data any more. How can I config the trigger tab? And I only need to sample the data at very low rate 0.5 s, can I record the data at this rate?
Thank you very much!
(5,736 Views)
Emma,
How are you trying to trigger the device? What signal are you trying to trigger using?
Kyle Mozdzyn
Applications Engineering
Kyle M.
(5,727 Views)
