SignalExpress
signal express initialization error
Installed ni-daqmx 9.0 / signal express 9.0 on a vista home premium system with a pci-6014 card.
System worked fine. could record and monitor all data.
turned off computer:  windows indicated there were some 121 files to finish installing.
turned on computer, and computer hung in middle of windows boot-up.
powered down, turned on computer again....  computer returned to previous safe configuration.
launching signal express resulted in "Initialization Error" pop-up.
Measurement and Automation tool can detect PCI-6014 just fine.  board passes test panels.
suggestions?
thanks,
jon
(9,403 Views)
Jon,
It sounds like your Signal Express installation was corrupted.  Have you tried performing a repair install on SE or even an uninstall/reinstall?
You can do this by going to Add/Remove Programs select National Instruments Software and Change/Remove.  Then Select Signal Express and either repair or uninstall.
Sincerely,
Jason Daming
http://www.ni.com/support
(9,386 Views)
That did not work.
(5,595 Views)
Another good step to troubleshooting corrupt installations is to try force reinstalling. Here is an article on how to do that:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YGwJCAW&l=en-US
Nolan H.
(5,581 Views)
Thank you for the reply.
Now working, however as far as I can make out it was the Microsoft Silverlight installation causing the problem.
I installed the latest version of Silverlight and then reinstalled Signal Express and this worked.
(5,571 Views)
