SignalExpress
signal express not saving logs, giving NaN
I need some help.
We have been using Signal Express for about 1.5 years with ok success. (It is really unstable at times.)
We just ran into a new issue the last couple of daysAll of a sudden it is no longer saving our log filesThere is no indication that there is anything wrongIt runs fine and appears to be saving the data (the logs show up in the log list on the bottom left side).
However, if you go back and try and open the data, it gives only NaN valuesIf you look for the log folder where it should be it does not appear and when you save, close and reopen the project, it says that the log files could not be found and have been erased.
We have restarted the computer and all the normalWe rebuilt the project from the ground up and it is still happening
There is plenty of disc space (15 Gb) so that shouldn't be an issue either.
Anyone have any ideas?????
Are there certain conventions we should stick to when naming the logsI thought it might be something with the names being used, but there doesn't seem to be a pattern.
Thanks for any advice.
(5,788 Views)
Please attach your project so we can take a look.  Also, what version of SignalExpress are you using and what hardware (if any)?
(5,778 Views)
