SignalExpress
signal express waterfall orientation
In the default waterfall graph for the 'Spectral Map' VI, is it possible to change the orientation of axis?
i.e. At the moment i have:
x = frequency
y = amplitude
z = time
and would like to have:
x = time
y = amplitude
z = frequency
(3,752 Views)
Hi Jarydmiles,
I've had a look in signal express at waterfall graphs and from what I understand you currently have a plot type of 'Frequency-Time' and you want 'Time-Frequency'.
In the context help on this function it states 'You cannot set Plot type to Time-Frequency, Time-Order, RPM-Frequency or RPM-Order for a waterfall graph.
Therefore I think that what you are asking for is not possible. However, you should be able to achieve the desired display if using LabVIEW.
Kind Regards,
Nathan
(3,701 Views)
