SignalExpress
signal express
Hello:
 I am using Signal Express with a USB-6009.  The attached sensor is a flow meter 0-5VDC output, scaled 0-5V to 0-500SLPM.
When running the software with no scaling, there are no problems. When using custom scaling, whether linear or map ranges I get flatlined readings at about 1 V output or 100 SLPM scaled output.
Any suggestions?    Thanks!
(5,663 Views)
how are you supplying power to the sensor?
what sensor type are you defining it as in Signal Express?
what are you entering for custom scaling values?
what's your min/max output range in the device settings tab?
attaching your project file may be most useful since the information you're giving is not very thorough.
SCXI- 1000 Chassis w/ 1346 adapter
PCI 6281 DAQ card
SCXI- 1520 Bridge Board w/ 1314 Terminal Block (x2)
SCXI- 1180 Feedthrough Panel w/ 1302 Block
Signal Express 2014.
Win7 Enterprise
(5,656 Views)
