SignalExpress
synchronise NI 9239 & NI USB 8473 with Signal express
Hello, I have a Cdaq 9174 chassis with an NI 9239 module (analogue input at 50Khz/ch) with Signal Express.
And I wanted to know if we could acquire this four inputs synchronised with datas from CAN connection by using a NI USB 8473 ?
Many thanks.
Patrick.
Message 1 of 8
(6,144 Views)
hello patlegain,
Are you using aVI import in Signal Express in order to user the 8473?
Sabri JATLAOUI - Certified LabVIEW Architect - Certified LabVIEW Developer
Message 2 of 8
(6,126 Views)
Hello, no we don't use VI.
We are just starting with NI systems and we're just testing with Signal express different kind of acquisition to know the opportunities.
Does we need absolutely to use VIs to acquire datas from the 8473? Is it very difficult to do?
Many thanks!
Patrick
Message 3 of 8
(6,124 Views)
For me you can't use the driver NI-CAN is not compatible with Signal Express. The Only way you could use it with SE, is to pass through LabVIEW VI.
You'll find in the below link the way to do it.
http://digital.ni.com/public.nsf/allkb/359D14941D6936E98625729D008387D5
I advise you to stay in LabVIEW this kind of program. It's easier.
Best regards.
Message 4 of 8
(6,121 Views)
Thanks for your advise, I saw that a CAN module for compact rio already exist, the NI 9862. I saw that this solution is better with hardware sync.
Is this one is directly workable by signal express, or does we need VI anyway?
Message 5 of 8
(6,117 Views)
SignalExpress can only be use with those drivers:
NI-DAQmx /NI-SCOPE / NI-FGEN / NI-HSDIO / NI-HWS / NI-DMM / NI-DCPower / IVI Driver Toolset.
SE does not support the NI-XNET driver that the 9862 runs on so it is not compatible. And i'm not sure that you can run a VI that uses this drivers on SE.
Best regards.
Message 6 of 8
(6,115 Views)
OK. We've found a solution, we used the shared variables from LABVIEW to transmit to signal express.
Thanks!
Message 7 of 8
(6,056 Views)
You are welcome.
best regards.
Message 8 of 8
(6,053 Views)
