SignalExpress
time averaging
Can somebody help me please with this problem? I am trying to perform time averaging from signal in Signal Express but the input and the output signals are the same. Attached is the printscreen of the process. Can somebody tell me what I am doing wrong?
(6,201 Views)
Hi milmuell,
let's take a look at your acquisition, so that we can work out what is the problem with the averaging.
What is your sampling rate? It might be possible, that averaging through 100 values is not enough to be seen in the graph. Could you perhaps log and post your measured data?
Jano
(6,185 Views)
According to the screenshot, you have only run this once (iteration count is one).  You can set your run mode to execute 100 times or continuously, then run until the iteration counter hits 100 or more and you should be good to go.  If you have problems, post your project and we can take a look.
(6,183 Views)
