SignalExpress
turn on solid state relay
My first Digital Out. USB-6210.
I want to turn on a solid state realy using  a DO line. Once turned on, it shall remain on until turned off.
I did DAQ Assist > Generate Signal > Digital Output > Line Output > DO 0 > 1 sample on demand.
I made a boolean constant, set to True, and connected it to DAQ Assistant Data, expecting it would output 5 V signal . I get a bad wire. What did I do wrong? Thanks.
(6,111 Views)
Hi knowlittle,
This is happening because the DAQ assistant is expecting an array of booleans as opposed to a single boolean.
If you place an array constant (Programming-> Array-> Array Constant) and then put the boolean in there, it should fix the broken error wire.
Let me know if you are still having problems!
Micah M.
NIC AE Specialist - Test
(6,099 Views)
