Software Defined Radio
Error reported by S-function 'usrp_uhd_sfunrx' in 'sdruFMMono/SDRu Receiver/usrp_uhd_sfunrx':
hi
I have received error and I couldn't solve it
is there any body help me
I will really appreciate every body help me
my problem is this when I run my program I see this error .when I run sdruFMMono
---------- begin libuhd driver construction output ----------
---------- end libuhd driver construction output ----------
---------- begin libuhd status message output ----------
Opening a USRP2/N-Series device...
---------- end libuhd status message output ----------
and I have seen this error in block diagram
Could not execute UHD driver command in 'createDriver_c': Could not create a UHD driver using IP addr '192.168.10.2'. Attach a device at the specified address, correct the specified address to match an already attached device, or continue to work in off-line mode.
Error from UHD: RuntimeError:
Please update the firmware and FPGA images for your device.
See the application notes for USRP2/N-Series for instructions.
Expected protocol compatibility number [7 to 10], but got 12:
The firmware build is not compatible with the host code build.
I can use uhd_fft and I am sure my USRP connect to computer and IP adress 192.168.10.2
but I can not update thisimage file
http://files.ettus.com/oldness/uhd_releases/003_002_003/images-only/
I have tried to update this image file but I couldn't update
is there special method to update that.
would you please help me ,how can update this files and then I can use USRP to connect hardware and analysis data
Comments
ErikL
NI Employee (retired)
on
Hello!  Please post UHD and GNU Radio questions to support@ettus.com
Contributors
