This example decodes an on-off-keying (OOK) key fob signal uing LabVIEW Communications System Design Suite and the NI USRP™ tranceiver.
For additional information, refer to https://forums.ni.com/t5/Example-Program-Drafts/Record-and-Playback-Demo-With-NI-USRP/ta-p/4099379
1. Open Acquire.gvi and navigate to the front panel
2. Populate the front panel controls as follows:
3. Run Acquire.gvi and press buttons on your key fob. An example of a decoded button press is shown in Figure 1:
Figure 1: Front panel of Acquire.gvi showing a decoded key fob button press
