Software Defined Radio
NI USRP-2920 Clock stability: Baseband frequency jumps
I am trying to do a labview program which is able to send a message from one USRP (2920 model) to other one. I programmed it using labview 2012.
I programmed a quadricorrelator for measure the frequency offset.
I programmed another VI to test it. This VI measures the frequency using the quadricorrelator and also a NI Phase-Lock Loop (PLL). After a while senging the symbol '1+1i' I get the following image:
http://forums.ni.com/t5/image/serverpage/image-id/120701i1A7F14A0F0C9C1E2/image-size/medium?v=mpbl-1&px=-1
The measured frequency sometimes jumps from one frequency to another one. I have no explanation. The USRPs are connected each other using the included cable and the attenuator. The ports used are the TX1 and the RX1.
Why is occurring that? Have I configured properly my pair of USRP?
I attached the VI I used.
Thanks in advance,
Xavier
Contributors
