Software Defined Radio
NI-USRP 2921
Hai, currently I'm trying to build a transmitter for IEEE 802.15.4, just for the PHY.
The standard specify the symbol rate for 802.15.4 is 62.5 kSymbol/s, Bit rate 250 kb/s
How I set this parameter in USRP.
I knew that 802.15.4 uses OPSK for modulation, but the pulse shape, I have no idea about this.
Does anyone, could enlight me about this.
Any comment would be appriciated, since I'm new to LabVIEW
Comments
wicak
Member
Member
on
And, I wonder in the ni-USRP Write data Tx, the transmission order, the array[0] or the last array is transmitted first?
Contributors
