Software Defined Radio
Prototyping Device-to-Device (D2D) Communication Using the LabVIEW Communications System Design Suite and the LabVIEW Communications LTE Application Framework
Download
 The code is available for download here.
Overview
The code provides the modification of the LabVIEW Communications LTE Application Framework that is necessary for D2D communications. This includes multi-UE support as well as the D2D communications. For details on the overview, please see the attached overview slide deck.
Hardware and Software Requirements
 You will need the following hardware and software to run the code.
LabVIEW Communications System Design Suite (Free evaluation)
LabVIEW Communications LTE Application Framework (Free evaluation)
At least 3 USRP-RIOs
In the attached overview slide deck, there is an instruction with screen captures on how to configure the front panels.
Additional Information or References
 This code is related to the following case study with TU Darmstadt:
http://sine.ni.com/cs/app/doc/p/id/cs-17689
Comments
Zotra
Member
Member
on
Hi, it is a good project  thanks for this.
but importattion of the project show this Error :
i'm using Labview NXG 2.1.1
Zotra
Member
Member
on
what can i do ?
