The current version of the NI USRP driver, Ver 1.1 is not available for the Mac version of LabVIEW or Mac-OS-based personal computers such as MacBook or MacBook Pro. Nonetheless it is possible to run NI-USRP from your MacOS-based computer using several approaches. One way to do so would be to use Bootcamp to run Windows OS natively. This document walks you thorough another way of doing so using virtualization software such as Parallels Desktop or VMWare Fusion. Our instructions focus on Parallels Desktop, but instructions for other alternatives will likely be similar.
Figure 1, PC-based LabVIEW application running on a Mac OS in a virtual machine.
The Secret is to run a Windows 7 virtual machine on you Mac with a network interface that’s bridged to a true Gigabit Ethernet port. With this configuration, on my machine I was able to establish receive rates exceeding 20Msamples/sec using this technique.
The following instructions will guide you through bridging a network connection:
Figure 2, Choose Devices-->Network 2--> Thunderbolt Ethernet (Bridged)
Set Up the Host Computer Network to a Static IP Address
If you are using Microsoft Windows 7 you can follow these instructions to set the host computer network interface to a static IP address.
2. Double click the Adapter entry that you wish to modify. The entry that you click could be for instance, Local Area Connection. A dialog box will appear. Click on the Properties button from the dialog to access the Local Area Connection dialog.
3. Double click the entry marked Internet Protocol Version 4 (TCP/IP4).
4. On the Internet Protocol Version 4 (TCP/IP4) dialog box, set the IP Address to 192.168.10.1 and the Subnet Mask to 255.255.255.0. Click OK to close the dialog and fix the settings.
5. Close the other open dialog boxes associated with network configuration.
6. Open the NI USRP configuration utility to confirm that the USRP has been successfully detected
7. You may need to disconnect and then reconnect the network bridge setting from the Parallels menu in order to see the connected NI-USRP.
