I want to implement tdma using GSP on USRPs. For now only two Nodes (as I have obly two usrps now) have to transmit for exact 8ms duration after every one second. Anyone done this before? I know that there is example VI on TDM, but that uses MIMO, I don't want to use MIMO cable. How much accuracy can I acheive? how to go about it? Any help would be appreciated.
Hello Brad -
We have some code that's not quite ready for prime time, but what you are describing is exactly the goal. I'll share it with you... but I warned you!
The code has a high level VI called main.vi inside of it we run the same subVI for each USRP. This allows us to develop once and deploy to many.
Accuracy is a very tough thing to measure, but its been accurate enough to do mimo. Its not coherent per say but the GPS's maximum possible accuracy is about 50nS. There are a lot of assumptions wrapped up in that number:
- Stationary GPS
- Antennas have clear view of entire constellation above
- Multiple sync'ed devices share satellites used for timing
- Antennas are of high quality with electrically matched cable lengths
As for what you're describing, if you achieve synchronized sampling clocks, then an IQ rate of 1 MS/s Tx is 1uS.
Here is the code I mentioned.
