Hello ilvanni,
In theory this is possible if your company IT department allows a VPN connection where a virtual network adapter connects your computer to the same network as the USRP.
You would need to place your USRP on the company network also instead of doing a direct connection to a computer.
USRP uses UDP to communicate (as opposed to TCP) and thus the packets are more likely to be lost (as opposed to TCP where packets get acknowledged and retransmitted).
I'm usually access the USRPs from my home using Remote deskop.
You might access your office computer through VPN or other methods, and it is possible to connect USRPs (but still from your office computer, not the home computer).
Thanks for answers.
I tested the vpn network, but there is error for the slow connection, I have packet loss.
Next week I try with remote desktop, will it work? will be stable? In theory I think so ... but ...?
continue ...
