Software Defined Radio
USRP as NFC reader
Does it is possible implement the NFC in a USRP to read/write on smart cards? The goal is test the maximum transfer bit rate to/from the smart card.
Comments
caesarherlamban
Member
Member
on
wow, this topic is so interesting. thank you sir, you open my mind in NFC topic. ive been using nfc with arduino shield and mifare classic card for my assignment, i'm just a student, i will do some researches and experiments, and i hope expert researcher in USRP will help with this topic too.
may be this information can help you sir, this is not labview, from the video i believe this experiment is using GNU Radio on Linux,
Contributors
