Software Defined Radio
USRP2 WBX DC problem
I'm using the USRP2 to sense the TV band. I do sensing in an entire 8 MHz DVB-T channel, the sample rate is 8Ms/s. The samples from USRP are in base band and sometimes appear a glitch at 0 it seems DC power. I've tried some technics as filter DC power or let run for some time consider stabilisation but were not efficient. I'm using a WBX daughterboard. Is there any suggestion?
Comments
ErikL
NI Employee (retired)
on
Hello -  It's great to hear that you've been able to get the USRP2 working with LabVIEW.  I recommend moving this question to the NI USRP Software Radio Discussion Forums that are monitored by our application engineering team and providng screen shots that show the problem you have encountered.
Contributors
