Sound and Vibration
Getting Started with Modal Analysis in LV
@MickeyD wrote:
The folder here contains a VI palette that gives you the basic building blocks for Modal Anlaysis.
Several pieces of NI software need to be installed before you download this palette. They are:
LabVIEW 2009 or later.
Sound and Vibration Measurement Suite 2009 or later
System Identification Toolkit 9.0 and later
Installation Instructions
1) Exit out of LabVIEW if you have it open. If it is already closed do not open it.
2) Download the Modal Analysis folder and save it in your user.lib folder for LabVIEW. The image below shows what it might look like on your machine.
3) Close the user.lib directory and start LabVIEW.
The VI pallette should be in your User Libraries. The following image highlights what it should look like.
Hi. First of all, special thanks.
well... I've some problem with modal test in Labview... could you help me out to how can I set a modal testing block diagram in Labview?
Message 11 of 12
(2,772 Views)
Thanks a lot. I added the file containing basic block diagram for modal testing But How can I use this blocks as my output? for example How can I collect FRF result pot?  And also I have not "DAQ assistant" option in "Express" section in Labview... How Can I add this too?
Message 12 of 12
(2,749 Views)
