Sound and Vibration
Sound Play Tone
Introduction
This VI plays a single frequency over a desktop sound card.
Supported Targets
  • LabVIEW Desktop (Windows / Mac)
Requirements
  • LabVIEW 2010
Implementation
This VI is written like an express VI: references and tasks are opened on first call, sound is output on every call (unless an output fails), and the stop input closes all tasks. Use the stopped output to wire into the conditional terminal of a loop.
The wait input causes this VI to block until the audio card has played all generated samples, so the execution time of the VI will be at least sample duration (s) long. Setting wait to false will cause the VI to return immediately; if used in an untimed loop, it will consume 100% CPU resources. Set wait to true and use in an untimed loop to generate continuous output without overutilizing CPU resources.
Sample Code
The following VI plays a tone continuously.
Versions
1.0 (2010-10-06): Initial release.
Message 1 of 1
(11,878 Views)
