Sound and Vibration
Swept Sine Phase Response Issue
I'm swept sine VI from sound and vibration which looks like this.
I am just trying out simple frequency response where I simply wire output signal to two input terminals (stimulus and response chanels) - so I should get frequency response magnitude equal to "1" at all frequencies and phase equal to "0" at all frequencies. However there is a phase shift which rises linearly with frequency. It says that I can customize the interchannel delay in DAQmx by setting the AI Convert Clock Rate. I'm kinda confused as to how to do it. Can anyone help me?
Thanks!
Stephen
(5,863 Views)
In case you are still interested, solved that issue years ago,
Kentmey
(5,359 Views)
