South East Michigan LabVIEW User Group
Next User Group Meeting 5/13/2021
Our next meeting will be on 5/13/2021.  JKI will be presenting on their new tool Project Dragon.
Project Dragon uses VIPM to help you better manage your LabVIEW projects:
  • Installs packages underneath your project source folder into a LabVIEW "virtual environment"
  • Allows you to work on multiple LabVIEW projects that each may use different versions of packages.
  • Multiple LabVIEW projects can even be open at the same time!
  • Provides a one-click setup experience when checking out LabVIEW projects from source code control
The time is different from our regular meetings due to the fact JKI is in California.  The time will be 1:00 - 3:00 EST.
Register Here
Dan Shangraw, P.E.
Message 1 of 1
(1,627 Views)
