Description:
AllDIO_FPGA_FromCustomPersonality.vi” is an FPGA personality that uses all DIO lines a strictly DIO. In order to create this personality, code used to split DIO lines into SPI and PWM was removed and replaced with code to simply use the lines as DIO.
Instructions on how to use Code:
Modified Pin-out:
< If your code is a new FPGA Personality, please add changed pin-outs in either an Excel spreadsheet or by modifying the pictures below>
< Please delete pin-out pictures if not relevant to your code>
Attach Code
